Sami Project
BigBoysToys
Wenatchee
This is my new project 87 Sami gonna give it a Toyota 22r toy transfercase and tranny and 85 toy axles. Should be a fun project.
Custom dentwork (previous owner):redneck:
Custom paintwork (previous owner):redneck:
Changing front axle to 85 toy axle
:D
Next get the rear ready for toyota axle pull the sami motor tranni and tcase and get ready for the toyota parts.
Looks a little uneven maybe I should fix that:bananadance:
Toy axle minus stock perches
Last time we will see the stock axle under there
:D
:D
:D
:011: Dont pay attention to the pink sidekick seat from toyzuki :puke:
We got the brake lines and a temperary drag link on today just to get it around the garage. The plan is to keep it cheap and beat the piss out of it. We've got alot of leftover parts from previous builds so its getting a 22r, 5sp,and case from an '85(harness, computer, and possibly pedal ass.). and I picked up another top shift today. All for free
:D In the end it should be a $250 sami built from spare Toyota leftover parts. Hopefully with duel cases if can figure how to make it work. Exocage new paint and bodywork to make it look pretty once, then wheel the **** out of it, roll it on the rocks and see how far it can fly at the sand dunes.
Well works been a little slow do to my real job. But got a w56 Toyota tranny, A second case for the duel cases, 93 Toyota power steering box and pump, EFI head and more to still come.
Kids playing
Stock Sami Vs
Motors gone
EFI head and intake
TCases
Power Steering
Yota Springs
Started trying to make it fit today got some trimming to do to the tunnel
Wanna sell your Sami trans, t-case, drivelines, and leafpacks?
If so, how much for it all?
Started toyota spring swap fpr front of sami with brackets touzuki built THANKS now just have to get the measurements for a double shackle and build the shackles.
Moved the center pin forward 1 1/2 to move the axle forward
Need to weld a 2x4 across the front of the frame rails for the double shackle.
Mocked into place for measurements
Got the toyota front leaf springs in the back of the Sami.
Got the motor bolted up to the tranny but I put the mounts for the motor are welded in the wrong spot on the frame so I have to move them.
Got the motor mounts moved and the motor bolted in today.
I also modified the grill a little for some originality.
BEFORE:
AFTER:
Good build. You should be happy with it. I have a few pointers if your interseted. I have done 5 of these swaps and doing another right now.
Worked on the tranny crossmember today.
Drilled holes in the frame to sleeve to bolt the cross member to the frame.
Crossmember
