Two weekends ago up at elbe, two buddies fawked up their transfer cases in their samis, so I decided to come up with a transfercase bucket for them. Nate broke the drivers side arm in half, while Pat just kept getting loose bolts, finally resulting in a broken case around the passenger side mount.
I searched online for ideas, and looked at all the major manufacturers t-case skid/mounts, and noticed, that all of them were a little different, some with the third rear output mount, but not the skid, and others with skid, but no third mount.
So I put all the goodies into one, and added a few also.
Now, I'm not finished yet, but it's starting to take shape, so I thought I'd post up some pics.
First, I started with a 4th (and 5th ) mount, right near the passenger side mount, because Pat's case will get reused with two of the 4 bolts still holding. This just takes some of the stress off of the stock mount on the case.
As you can see, the 5th mount is just the stock "skid" welded to the new skid.
I also retained the stock passenger side arm, which will get reinforced, and basically started building off that.
Now, I still have to close in the front, which will get tied into the front output bolts, plus add some reinforcement to the new drivers side arm.
:corn:
:corn:
