located in Clearwater fl. $800 and you can have it all. this ia a bolt in cage with frame tie ins... you have to weld the tabs on the frame. quick connects on the front. everything has rock rash put with a new coat of paint sure would look purty. chef 727 422 5922
A buddy keeps his 81' at my house when hes outta town, he could be talked into this. How does it attach at the A pillar with the quick connect? did you have to weld the other half of it to the body/frame?
the quick connects twist together and have set screws. you could not get the cage in or out with out them. the 4 corners of the cage are plated and the frame tie ins bolt to that. 4 sets of tabs are welded to the frame, 2 front 2 rear. 2 small sliders weld to the rear of the frame to protect the overhang on the tub. I've wheeled my scrambler pretty hard and this stuff works !
