J Jay1 Well-Known Member Joined Jun 11, 2006 Messages 142 Mar 10, 2007 #1 How do I check to see if they work on a warn winch?
B blackcj71 Well-Known Member Joined Mar 27, 2006 Messages 1,509 Location Kirkland Mar 11, 2007 #2 Hook up your positive/negative for the winch then hold switch either direction and check to see if power is switching on the solonoid. Both big terminals on the solonoid should power up.
T TDW Well-Known Member Joined May 12, 2006 Messages 250 Mar 11, 2007 #4 Power on one of the small terminals, ground to the other then check the resistance between the two large terminals. Should be around 1 ohm or less.
D dr drae Well-Known Member Joined Oct 17, 2006 Messages 1,054 Mar 12, 2007 #6 What are silonods? You mean like missle silonods? :flipoff:
