DEM Blower kit LS
Magnuson cathedral port lower manifold
Billet adapter plate to blower pattern
Billet A2W heat exchanger
Billet fuel rails
Crank pulley pinning kit
TB adapter plate to LS 4 bolt style TB
102mm DBC TB with accelerator cable bracket
Brand new M122 supercharger
Truck spacing for single belt line.
Compatible with LSA belt line for dual belt system.
Identical setup made 525hp & 560ft/lbs at the wheels through a 6l90 and a 3000rpm converter. On 93. No need for race gas. Torque curve is amazing.
I have the list of every single part you need in order to put this together. I also have some extra things I'd let go with it (in-tank 525LPH fuel pump, hydramat, brand new LSA water pump, brand new LSA crank pulley, etc). That said, this is not a plug n play setup. You better know your way around engines and be crafty.
$3000. Free shipping for a Hardline member.
Billet fuel rails
