richardsonsfab
Member
- Joined
- Oct 26, 2014
- Messages
- 8
Selling my 2013 bouncer/crawler buggy that's been wheeled about
Motor
stock chevy 6.0 lq4 with a mellings high volume oil pump, corvette oil pan and modified oil pickup tube, wiring harness and tuning by schwanke short blocks.
Transmission
th400 that has been totally rebuild with upgraded 4l80 sprag and clutch packs, b&m manual shift with automatic features, capable of holding 800hp, dearal transmission cooler with fan
Transfercase
atlas twin stick 4.3 with 32 spline front and rear output shafts
Drive shafts
toms wood custom 2 piece front drive shaft with 1350 u joints, and a tom woods custom 1 peice rear driveshaft with 1350 u joints
Axles/front
complete dana 60 king pin, 4:10 gears, Detroit locker, Yukon chromoly 35 spline outer shafts, spicer u joints, Yukon chromoly drive flanges, 3/8 thick diff cover with truss support and a 1-3/4 .188 wall tubing truss
Axle/rear
complete 14 bolt corporate, 4;10 gears, Detroit locker, stock shafts, chevy 3/4 ton disc brake conversion, 3/8 thick diff cover with truss supports and a 1-3/4 .188 wall tubing truss
Chassis
2 seat- 1-3/4 .120 wall dom tubing and 1-3/4 .188 wall dom tubing on the bottom
Skid
1/2 inch 6061 aluminum that covers the whole bottom
Shocks
14 inch travel king coilovers front and rear
Suspension
triangulated 4 link front and rear, .2 inch .250 wall tube links with 1-1/4 heims both upper and lowers on front and rear
Steering
full psc hydro kit, single ended ram, aluminum reservoir, derale cooler with fan
Plumbing
all Russell stainless braided fuel lines and fittings, fragola push lock tranny lines, and all stainless braded brake lines
Brakes
willwood 1 inch dual master cylinders with single pedal and 4 wheel disc brakes
Cooling
rear mounter griffin radiator with single 16 inch electric fan, -20 an fittings
Tires/wheels
42inch super swamper iroc's on 17 inch steel wheels with weld on 32 bolt outer bead locks
Interior/ accessories
full steal floor and firewall coated with rhino liner, auto meter gauges for trans temp, coolant temp, oil pressure, volts and tach, upper mounter switch panel,
interior light, aluminum roof, twisted stitch seats with crow 5 point racing harnesses, seaward 20 inch off road light bar, rear tail light, optima red top, aluminum fuel cell with no foam, walbaro 250 fuel pump,
corvette fuel regulator for single line hook up, and the warn winch not included but I am leaving all the hookups for it
located in Pittsburgh PA
contact Justin for any question about anything
phone number is 724-630-5647
asking price is 32000 obo
Motor
Transmission
Transfercase
Drive shafts
Axles/front
Axle/rear
Chassis
Skid
Shocks
Suspension
Steering
Plumbing
Brakes
Cooling
Tires/wheels
