Will try to cover every detail about buggy but if your interested contact me and ill cover anything i may forget because its nearly impossible to list every little thing about it.
chassis:
full 1.75" dom tube with metal floors/firewall/tunnel,removable aluminum side panels.aluminum dash panels and console panels
hard coolant pipes ran to rear,grab bars for rear passengers
engine cradle with poly bushing mounts, trans cradle with poly bushing mounts
buggy is painted with tinted raptor liner for durablility and easy touch up down the road.
drivetrain:
500hp 02 ls1 with ls6 block,ls6 intake,double valvesprings W/***anium retainers,g5x4 cam,5" underdrive pulley,tuned ecu,custom harness
fresh truck th400,2200 stall convertor,chrome pan with drain
b&m hammer shifter
advance adaptors th400-np205 adaptor,fresh ford np205.
cable shifters with billet twin stick shifters
rear mount afco radiator with flexlite dual fans
all coolant fittings are 20an fittings
dual pass trans cooler in rear
1350 f&r output yolks on tcase.
2" driveshafts f&r with slipjoints,spicer ujoints
fresh rebuilt rockwell steer axles f&r
both axles mowhawked and flipped hubs
rear chunk is flipped to be centered,front has tophat for bumpstop
mrw 17" rockwell beadlock wheels,49x17 super swamper irok's
block hugger ceramic headers,exhaust ran to pass. rear with slp resonator
suspension&steering:
FOA 18" resivoir coilovers,tripple rate kit,5" extended ends
triangulated 4 linked front and rear,1"heim joints on all links
all link brackets were custom built from mudpro along with coilover brackets
polyurethane bumps f&r center, 6ply limitstraps on all 4 shocks (not pictured)
psc pump with bracket and pulley,8x10 f&r rams,tg orbital
electric rear steer valve,electric joystick,quick connect steering wheel
2qt resivor with built in filter,dual pass 15" aluminum cooler
parker hydraulic line throughout
misc:
autometer sportcomp gauges(trans temp,oil pressure,volts,fuel level,water temp,5"tach)
wilwood dual resivoir brake pedal assy, ss braided brakeline f&r
pinion brakes with wilwood rotors,4 piston calipers
lockar gas pedal & throttle cable
paneltronix 8 switch fused rocker panel,4 slot fuse block under dash
data port and 4 slot power outlet under pass.dash
batt. disconnect,keyed ignition with push button starter
pioneer cd/mp3 player with marine cover and 4 marine 50watt speakers
2 quick pull extinguishers under front seats
waterproof storage bags on console
dual yellowtop optima batt. in dual batt. hold down
20gal fuel cell with sending unit
mallery fuel pump,corvette reg/filter,russel inline filter filter,an fittings/line
rock lights on rear,sportcomp headlights,led taillights
corbeau baja ss seats in f&r,simpson 4pnt harnesses
smittybilt xr10 winch with synthetic winch rope and wireless remote
this buggy is fresh and has couple trail rides since complete, very capable and impresive rig. sits 4 adults with room to spare. Will continue to wheel until sold.
Price drop to $33k. call/text 4237021646 located in chattanooga,Tn
No trades cash only
chassis:
drivetrain:
b&m hammer shifter
misc:
No trades cash only
