2 seater chassis. 108" wheel base and 19" to lowest part of belly.
4-linked front and rear with 3/4x3/4 heims on top and 3/4x7/8 heims on bottom. All lower links are dom
42" tn cut tsl on recentered h-1's with rock rings
4.3 tbi on propane, def not stock but not 100% sure of exact hp
700r4 with rev man valve body
4.7 yota case twin sticked
Cucv axles with artec trusses locker rear and welded front. All stock with 4:56 gears
14" FOA coil overs on front, 14" FOA coil overs going on the rear as soon as I can get some tubing bent and put on, All 4 just rebuilt with new seals and shafts, 4" air bumps up front also new.
Full hydro steering with single ended tsc ram
New orbital
New steering wheel
New auto meter gauges
All new rocker switches
Corbeau seats
6 point harnesses
Skid plate
M8000 warn winch
Aluminum radiator
Msd 6al box and msd distro
I'm sure I'm forgetting a lot. Call/text 270-805-1106 and I will answer any questions you have.
Located in campbellsville, ky.
New orbital
New steering wheel
Corbeau seats
6 point harnesses
Skid plate
M8000 warn winch
Aluminum radiator
