1slowhatch
- Joined
- Feb 21, 2012
- Messages
- 420
'01 Wrangler TJ, stretched front and rear (118" WB), SRW Chevy D60 Front and 14 Bolt rear, matching 4.10 gears. Blue Torch Fab built custom roll cage, skid plate, chassis link mounts, shock hoops, etc. BTF rear frame replacement. All the welds/fab work on the chassis look amazing, very professional work. I believe the cage is DOM. Has Hunsacker seats mounted with 5 point harnesses, and aftermarket gauges in factory dash.
It is a roller, no engine trans or t case. Comes on roller wheels/tires.4 linked front and rear with 1.5" .250 wall DOM tube, heims and links are all new.
Axles have homemade trusses, rear is welded, open front. Front has beefy diff cover, includes tie rod over knuckle and single high steer arm. Rear has been disc brake swapped. Axle side link mounts are just tacked, and will need some work.
$4500 Reduced to $4200 for everything. **AXLES AND LINKS SOLD. MAKE OFFER ON CHASSIS OR WILL PART OUT.** Located in Knoxville, TN. Delivery can be arranged.
**ALL SOLD**
865-660-1244. Text/call. Serious inquiries only please.
**ALL SOLD**
