Time for a new build!
LS 5.3 L33 all aluminum block and heads
Moroso 3 quart oil accumulator with electric actuator stainless steal oil lines an10 fittings
Procomp intake aluminum
Procomp 80mm Throttle Body and fuel rails, an6 fittings w/ inline fuel pressure gage
K&N air filter
Stainless steal Shorty headers, Dynomax flow exhaust
Stage8 locking header bolts
Lokar locking oil dip stick
New alternator and water pump
Front 14bolt 4:10, Branik Motorsports 40 spline inner shafts,Nitro spool, Crane inner seals, CTM joints, 35 spline Yukon stubs, Wildwood breaks, custom inner and outer knuckles, poly performance Drive flanges Rear 14bolt 4:10
Built th350 transmission, aluminum deep pan, 2700-3000 torque convertor, B&M cooler with fan, Advanced adapters flywheel and spacer, Lokar locking dip stick, Art Carr-Winters shifter, reverse manual valve body
Transfer case doubler 203-205 twin stick,
14:10 Ujoints on driveline
Double triangulated four link front, aluminum 2.25" lower
Links, 2" .250 wall upper links both 1.25" Aurora joints w/ 1" through bolts
Double triangulated four link rear, aluminum 2.75" lower links, 2" .250 wall upper links both 1.25" Aurora joints w/ 1" through bolts
FOA 18" 2.5 coil overs... 200 over 250 and 150 over 200
Auto meter C2 gauges, rpm, temperature, oil temperature, trans temperature, fuel pressure, fuel level, kill switch, toggle switch push button start.
6 Baja design rock lights
CNC Floor Mount Dual Cylinder Brake Pedal Assembly with residual valve all stainless steel brake lines
PSC 2 1/2" Single ended ram,PSC reservoir, PSC high-volume pee pump, PSC orbital valve, AN12 return line, AN8 pressure line, AN6 feed lines, 3 inch trophy truck power steering cooler
ORA diff covers and axle truss pinon gards
Optima blue top
Ramsey 9000 winch with newer 15,000lbs synthetic rope
Speedway three core aluminum radiator dual 12" fans
Aluminum 16 gallon fuel cell, LS1 fuel kit from MSD, 10 Inch Aluminum Fuel Filter, Stainless Element
Cd player wakeboard speakers,Pyle 8" inch sub, Pyle 1200 W amplifier
Corbeau Baja SS Off Road Suspension Seat, four point seatbelt harness, inner air lock head restraints
43" SX tires with Inner Air Lock bead locks and rock rings
Also outdoor cover.
188wall lower frame rails, 1 1/2" schedule 40 chassis
1/4" aluminum skid plate
Custom tote bags
118" wheel base, 23" belly pan, 74" tall
$20,000
231-313-0661 or Tex Shawn
Traverse City, Michigan
find more pics here... some are old build pics, can send more.. thanks for looking
https://www.facebook.com/photo.php?fbid=1196617413685828&set=ms.c.eJxN0FkOAzEIA9AbVRDW3P9inWKN6e%7E_TcSCqN1PL1bKjT3%7E%3B0hRK9mkoIsTh%7E_%7E%3B2ASUYQGOOGiVF6Ig8SCTWkbIWdE%7E%3BwCJHamBuoQGcPVEadnCPGscSZ9XJAg4rnhcyUAmoEP96TjWTXhGni84SijLuhJnASPxwpFJ%7E_CXodOgmFCMsPQcJJ%7E_Qkios9X%7E%3BpLyJY2oBfwLEvNkLCFSRhLzQFczHCtsMNl9khe63NL3lhAYkcOQAizae6fOn4s4gv6iYZY.bps.a.1196616703685899.1073741826.100000127433192&type=3
K&N air filter
Optima blue top
Also outdoor cover.
Custom tote bags
$20,000
