Beefcake
call or text with questions 513-four nine zero - 3984
Update just got coil overs tuned!
Very interested in trades like real estate, farm equipment, Lincoln continental, built jeeps that are still street legal, 4 seat rzr plus cash, newer diesel trucks, newer SUV, wake board boat, newer corvettes. Could be interested in other hot rods or classic cars no junk.
2018 custom built 4 seater trail bouncer
-1.75x.120 and .188, 1.5''x.120 and some 1''x.120 all DOM
-1/4'' 5052 Aluminum skid from front of motor to back of transfercase
-116'' wheel base, 23'' belly height, 70.5'' overall roof height
-5.3 truck engine, new gaskets, BTR cam, new pushrods, springs, head studs, ls7 lifters, AL Holley oil pan, Moroso 3qt accumulator, schwanke engines ecm and harness, Dyno tuned by Brad at Tin Solider Race Cars 270 to the wheels with sheet and videos.
-TH400 upgraded pump, sprag, drum, reverse manual valve body full manual, freshly rebuilt, Locar braided SS locking dipstick, Huges 2500HD torque converter.
-Altas 2 speed 3.0:1 hard linkage not cables 1410 yokes.
-Front axle custom drivers drop 14bolt FF, Custom 40 spline spool, spidertrax 40 spline 300M shafts, CTM 300M u-joints, Yukon 5.38 gears and bearings, Solid Axle industries high steer arms (keyed) spindles, Knuckles and bearings, Reid bronze king pin bearing eliminator, full truss, TMR 15 bolt shave kit with diff and pinion guard, full hydro PSC 2''x8'' ram, 1410 yoke.
-Rear 14bolt FF yukon spool, yukon 5.38 gears, full width truss, TMR 15 bolt shave kit, pinion and diff guard. stock shafts. 1410 yoke.
-1410 drive shafts .250 wall DOM machine fit, with drive shaft kit from sunfire offroad, midship and front shaft were balanced by Cincinnati Driveline.
-14'' X 2.5'' Radflo coilovers with remote reservoir front and rear, radflo 4'' hydraulic bumps front and rear, AL Currie Anti-rock sway bar, sunfire offroad limit straps, 2-1/2'' 7075 AL link bars, 1-1/4'' chromoly heims.
-3/4'' Dual Wilwood MC and pedal assembly, all SS braided -3an lines, rotor and caliper kit from LUGNUTS 1/2 ton chevy kits.
-Twisted Stitch full suspension seats extra wide, front google pockets, matching rear bench seat roughly 36'' wide fits two youth riders, custom colors and stitching, PRP racing 5.2 padded harnesses front youth 5 point in the rear.
-Custom built .125 thick AL fuel cell with sump fully tig welded and pressure tested then powder coated clear, 100 micron -6 pre filter, LS regulated return from WOD.
-All wiring is 10 gauge copper wiring, water proof weather pack connectors, every component is a different color wire for easy navigation, every connection has been heat shrunk and all wire has been loomed with quality expandable loom not **** plastic. Small components are in a fuse block, large (fuel, ign. fans etc.) on 40 amp weather resistant relays, dash is on 20 amp circuit board by 12voltunlimited.
-Griffin aluminum radiator with dual fans ECM controlled, derale performance trans cooler with fan, derale performance PS heat sink dual pass, all lines are high end crimp push-lok or nylon braided with AN fittings.
-mixed LED lighting all top end rigid industries, life time LED etc.
-interior - auto meter liquid filled gauges with back light, joes racing quick disconnect steering wheel, art-carr sidewinder shifter, neutral safety/reverse light switch.
-Wheels new 43'' SX stickies, Trail Worthy Fab double bead locks re-centered, rubber run flats inside, rolled ring inner lip for reinforcement.
probably forgetting something
price $42,000 OBO or trades plus cash or trades.
