flat broke
- Joined
- Apr 8, 2009
- Messages
- 326
Jimmy Smith 2010 Rear Engine Buggy
Located in Chattanooga, TN
Any Questions Please Call Jimmy Smith @ (423) 827-4913
Buggy Sounds Awesome and Performs Incredibly. Only has 4 rides since completed.
$35,000 (Don't let this one get away)
Engine:
461 CI
13 to 1 Compression
Balanced Rotating Assembly
Oval Port Heads
Comp Cams Solid Lift Cam
Air Gap Dual Plane Intake
Roller Rockers
10 Quart Milodon Oil Pan
High Flow Aluminum Water Pump
1 to 1 Billet Pulleys
Aluminum KRC Power Steering Pump (9.6CC
Impco 425 Propane
Custom Built Headers 2 1/4 Primary Tubes 4inch Collectors
Transmission:
Fresh Turbo 350
3000 TCI Stall Converter
Transfer Case:
Twin Sticked 205
32 Spline Input and Output
All New Bearings and Seals
Woodley Clocked Adapter
1350 Yokes
Front Axle:
Dana 60
528 Gears Yukon
Yukon Chrome Molly 35 Spline Inner and Outer Axles
Solid Drive Flanges
Rock Crusher Diff. Cover
1/2 Ton Calipers 3/4 Ton Rotors
Rear Axle:
14 Bolt
538 Gears Yukon
Yukon Chrome Molly Axles
Rocker Crusher Diff. Cover
Both Axles Have Been Cut and Flipped with Custom Built Trusses
Link Bars
2inch Solid Aluminum Uppers
2inch 1/2inch Wall Dom Lowers
1 1/4 QA1 Heims
Front Tires - 44inch TSL with TN Cut on 15inch Bead Locks Wheels
Rear Tires- 16X21.5 Goodyear Turf Tires on 16inch Bead Locks Wheels
5500 Pound Winch with 1/2inch synthetic Rope (50 Foot)
17inch Kirkey Aluminum Seats with Black Covers
B & M Shifter
Autometer Silver Face Gauges
5inch Monster Tack
100 amp 1 Wire Alternator
High Torque Racing Starter
Probillet Distributer with MSD Coil
Custom Built FSR Radiator with Dual 16inch Fans and Custom Shroud
All Braided Lines and AN Fittings
Engine:
461 CI
13 to 1 Compression
Oval Port Heads
Roller Rockers
Impco 425 Propane
Transmission:
Fresh Turbo 350
Transfer Case:
Twin Sticked 205
1350 Yokes
Front Axle:
Dana 60
528 Gears Yukon
Solid Drive Flanges
Rear Axle:
14 Bolt
538 Gears Yukon
Link Bars
1 1/4 QA1 Heims
B & M Shifter
5inch Monster Tack
