slravenel
Solid Axle Industries HP D60 rear axle
-5.38 gears
-OX locker
-5x5.5 bolt pattern can be converted by using off the shelf Solid Axle parts for ~$400-$500 (http://solidaxle.com/ProductCart/pc/viewCategories.asp…)
-Full Float
-Disc Brakes
-4340 shafts
-300M drive flanges
-1350 yoke
-1.5 inch aluminum spacers are on it now and will go with it if the buyer wants them (~67.5" wms with spacers)
-Currently is set up for a 4 link, but is clean otherwise (no truss or extra brackets)
-It will be cleaned up and a fresh coat of paint put on prior to sale
Axle was in my old buggy, it has been used and ridden. It is not bent or damaged in any way other than the normal scraping on the underside. I'm not even sure you could dent it up if you wanted to anyway. This is NOT a junkyard axle. It is basically this one, but with an OX locker instead of a Detroit (http://solidaxle.com/ProductCart/pc/viewPrd.asp…)
$2500.00
This would be a great swap in axle to beef up that stock rear end!
Located in Atlanta, GA
-5.38 gears
-OX locker
-Full Float
-Disc Brakes
-4340 shafts
-300M drive flanges
-1350 yoke
$2500.00
