mtngaprock
I put a set of the super atv a-arms on my 800s and the kit came with steering stops. Can I run with out the stops and be fine. As in right now the stops are on and the rzr just don't turn the way it did before.
rednecklights said:Jack it up and turn the wheel till it stops , if the cv binds then run the stops satv sent. if it dont, rock out!
ibrokeit said:Pretty sure on the forward a arms, they need to be there to keep from breaking axle from binding.
ibrokeit said:How do you like the arms? Mine came in last night. Itchin to get them on. Did you have to pull any of the front plastic to install?
rednecklights said:take the nut off.
slide a-arm bolt out till it hits the front clip.
pull a-arm down and slide it off the a-arm bolt
