Survey Says??
money_pit_yj said:
Here it is. Moved more fuel in one month than I did the last year.
**EDIT Pics wont post
Wow, congratulations, that's quite a turn around. Since the pics aren't uploading, what did you end up doing?
Function over form. High volume pumps, satellite pump to fill both tanks at once, farm fuel pumps, and a gas pump. All laid out where every pump can be used at same time.
When towing it's mostly about easy in and out. Pump lanes should be parallel to the road so I can pull in, get fuel, and pull out without any major turns.
1: Price
2: Being able to get in and out
3: It should be somewhat clean
4. Pay at pump
5. Fairly close/on the way/location
