redneckengineered
Trailer Park Panty Dropper
PTC built TH350, FMVB with compression braking. Problem is the tranny has zero compression braking. Other than screwing up and installing the incorrect VB what could cause this?
slravenel said:did it lose braking? or never had braking?
No real help here.redneckengineered said:Never had it. PTC insists it was built correctly. Long story short this was done over a year ago and we were too busy riding every weekend to pull it out, send it back, and wait around with our thumbs up our asses for however long it would have taken to get sorted. Tranny is tits otherwise, shifts great and takes a beating. Now too much time has passed to do anything about it with PTC. I was just sitting here curious this morning wondering if there could be a simple fix or if it will just have to be something that is addressed on the next rebuild (hopefully a long time from now).
CHASMAN9 said:You can have my compression braking. LOL I hate it and will be having it removed soon. When down shifting from second to first, it [size=10pt]STOPS[/size] you into the steering wheel. I hate it, that is all...
ADMINISTRATOR
I dislike it in high range, I wish I had gone fmvb, so that it could easier bump it in neutral without sliding through all 3 gears, even with my gates modified on the winter's shifter.CHASMAN9 said:You can have my compression braking. LOL I hate it and will be having it removed soon. When down shifting from second to first, it [size=10pt]STOPS[/size] you into the steering wheel. I hate it, that is all...
ADMINISTRATOR
redneckengineered said:I absolutely love mine in my TH400. Jess would like it to work in her TH350. It's nice to be able to throw it in 1st coming down some steep hills and not even tap the brakes. Great for trail riding. Racing maybe not so much.
CHASMAN9 said:You are right about one thing, it will stop you when you throw it in 1st coming down steep hills and not even tap the brakes, but then again, brakes are overrated and a few well placed Quercus Virginianas will slow down any buggies and are good for traction.
ADMINISTRATOR
redneckengineered said:Mine isn't that bad unless I'm hauling in 3rd and throw it into 1st. But if I'm just cruising I can go to 1st and it's not too abrupt. I usually go to 2nd which offers a medium level of compression braking then to 1st. Or I just leave it in 2nd depending on how much I want. I actually have a regular VB though (not manual VB) I don't know if that makes a difference.
When I went to the manual vb in my buggy I had an option of which gears I wanted to have brake. As far as I know you are correct but I'm not a transmission guy.redneckengineered said:So basically what I'm hearing from you guys is that if there is no compression braking someone likely assembled this on Friday at 4:30 and grabbed the wrong VB.
bigs10blazer said:is yours a reverse manual valve body ? most that are reverse manual valve bodies dont have compression braking, i have a 350 that is reversed and does have the compression braking , for some reason( i dont know why? ) but when you reverse it its hard to put in the compression braking part
mike2.5 said:I purchased a TH400 from PTC maybe two to three years ago. At the time Ed would not build it with a compression braking vb for off road. Maybe they didn't put one in it?
