RustyC
- Joined
- Dec 15, 2010
- Messages
- 1,251
I will soon be in need of a new trailer to haul 2 rigs. One is a YJ on 42's and the second is a buggy on 37's. The jeep is 4700 lbs and the buggy is 2800 lbs.
Total of 7500 lbs. I need 26 ft of deck minimum. I am considering building a trailer myself. I have one now that I built and it works perfect just to short. My current trailer works too good to cut up and change so a new one is needed.
The towrig is a 2002 F-250 7.3L srw 4wd cc with an ugly paw paw camper shell on the bed that is way better than any tent I've ever slept in. It keeps everything dry to and from the parks so that rules out a gooseneck.
I have been thinking lately of building a tilt trailer or using airbags to eliminate ramps. I could go hydraulic tilt without issue since I already have a electric hydraulic unit if needed.
Tilt trailer loading plan would be tilt the rear section of the trailer (dovetail) down load them up. Raise the dove and tie down.
Air bag trailer would be set up using 4 trailing arms+ trackbars. Airbags and shocks. Loading plan would be dump bags, load, raise and tie down.
Failure of the tilt would be little issue, a jack or a buddys ramps and I'm on the road. Airbag failure = cutting firewood to hold the axle up?
Both designs would yield a good departure angle. Hydro tilt is less complicated to build but the airbags sure would ride nice.
Anti sway, weight distribution hitch is a given either way.
Any advice from those than like to drag things around with their truck?
Current setup
Current setup
