snowgoon
is there a trick to getting the pin that holds the shackle to the leaf or do i need a bigger hammer?
using a grinder makes it hard to reuse it ...........is it reuseable or do i need a new one?
Eh... i just use a bolt and grind around the head once i need it to fit into the perch
Big F*in Air Hammer!!!!!!:awesomework:
Your reading comprehension sucks. :fawkdancesmiley:
Mine rusted/fused itself tothe metal inside the bushing. A good ole cutting torch took it right out butit required a new bolt and bushing. I just used some grade 8 bolts from the local hardware store and they held just fine. Make sure to re-torque them every few hundred miles till they stop slipping lose.
