Few things to try
-Disconnect the knock sensor connector and check for a key on engine off reference voltage of 0.015 to be applied from the Electronic Control Unit (ECU).
- Check for AC output voltage on a lab scope coming from the knock sensor during crank. A very small amount of voltage should be present.
- Revving the engine between 3500 and 4000 RPM, a frequency reading of 7000 to 8000 Hz should be coming from the knock sensor. If the knock sensor signal tests good at the ECM, the ECM could be faulty.
The wire harness on the knock sensor can get brittle and break a few strands of wire when the harness is moved during a cylinder head replacement. Chances are extremely good that the harness under the intake manifold has a few broken wires. Knock sensors rarely fail but when taking the intake off to replace the sub harness, it is a safer bet to replace the knock sensor as well to avoid repeating the labor for free.
