Sold/Expired Toyota V6 3Rd
84turbotoy
2
Cordova, Al
Toyota v6 3rd member, I think 308 is what I came up with on gear ratio. Also have housing and axles if you need the complete setup. 75 for the chunk
84turbotoy said:
Haven't bumped this since last year :****: Offers?
That must be from a 2wd v6 truck or something, the outer casting looks like a V6 3rd, but the carrier is a 2 pinion (single cross pin) instead of the usual "clamshell" 4 pinion carrier found in v6 3rds.
Can you measure the carrier bearing size? I'm curious if it's 50mm journal or a 45mm.
The Hi pinion 8" fronts use a carrier like this (2 pinion, single cross pin, 50mm "v6 carrier bearings")
I will check and see Nick, It came in the rear of my 84 solid axle and I knew something wasn't right when I put it in 4 low and ended up with this so any help would be appreciated.
What gears are you running? I have a several spare sets of 4.10 on the shelf if you wanted to regear it.
I swapped back to the 4cyl housing for ease of same pumpkins, always carry a spare to the park incase I pop one! :****: :driving:
