nighthunter
Ok soo i fired up my truck tonight got down the road a mile or so around 3500 rpms in 3rd 4th n 5 gear the truck starts cutting out but once im up to about 4 k it stops. The symptoms act as if my plug wire was undone soo i get out check everything looks fine. Get home checked vaccume hoses fixed one that had a hole in it found a plug wire that kept fallin of the dizzy fixed that and threw some isoo heat in the tank just for the hell of it.
get back in fire it up drove about 20 miles only encountered the prob once so i was like ok maybe i had some bad gas drove it another 20 or so mins and it happened a few more time sooo took it home and parked it.
The last thing i did in it last night before i had these issues "today" was fill my tank up with gas. what do you all think it may be?
Tps
gas
injectors
fuel filter just replaced it tho
vaccume hose
idk but what ever it can be i would greatly appreciate the help i tried useing the search as much as i could and read up on it but still having a hard time figureing it out
specs: 91 toyota 4x4 22re with aprx... 220k
Tps
gas
injectors
vaccume hose
