Sold/Expired Trail Gear - Best Price Guaranteed!
Trail Gear Trail Safe™ Knuckle Ball Wiper Seal
Tired of wiping big clumps of dirty sandy grease off of your knuckle balls after every trip? So are we. We asked our engineering department to look at the problems with the OEM design along with what was currently offered on the market and they came up with a one-piece, high grade polyurethane seal that is durable and will give you a lifetime of dependability.
Trail Safe™ Knuckle Ball Wiper Seals are without a doubt the best in the industry. No other design is comparable in performance and quality.
The Trail Safe™ Knuckle Ball Wiper Seal is a double sided seal that keeps grease in and dirt out, all while eliminating the use of the OEM felt and rubber. Since it is made from seal-grade polyurethane, not UHMW, the seal is pliable enough to stretch over the knuckle ball during installation. This eliminates the need to cut the seal for installation which allows water to enter the knuckle ball and for grease to escape.
Trail Safe™ Knuckle Ball Wiper Seals are sold in pairs with our legendary Rock Rings. One kit will complete one axle.
Kit Includes:
(2) Trail Safe™ Knuckle Ball Seal Wipers
(1) Rock Ring Kit
(16) Rock Ring Bolts
(16) M6 Lock Washers
Tacoma Universal Rear Bumper Kit
Somewhere along the evolution of a Rock Crawler your pickup bed is bound to get removed. The Tacoma Universal Rear Bumper Kit will help you finish the job right. Designed to weld across your frame rails, this kit provides strength, utility, and a clean look. We started with a piece of 3 ½” x 2 ½” x .120” wall A-36 rectangular tubing, and 6.25” receiver tube. Also included are a 1/4” thick receiver gusset, and two 3/16” steel plate end caps. The Main Frame tube comes 40 7/8” to fit stock Tacoma frames but can be trimmed down to fit various other applications. These parts are shipped Raw, and require welding for installation.
Trail Gear Chromo Spindle Nut Kit
In many cases, stock wheel bearing nuts and star washers can be used several times. However, with the increased maintenance required of an off road vehicle, these will need to be replaced. Trail-Gear now offers a Chromo Spindle Nut Kit that allows you to more easily service your axle and decreases your long term service costs. The Locking Nut and Washer have been CNC machined from 4130 Chromoly. The Nut has also been heat treated to Grade 8 standards. Kit comes with the hardware necessary for one axle.
Advantages over stock:
Stronger than stock. Made out of 4130 Chromoly.
Extends the life of your wheel bearings due to loose spindle nut and OEM lock washer.
Ease of installation.
This kit includes:
Thrust Washer (qty 2)
Spindle Locking Nut (qty2)
Spindle Locking Washer (qty 2)
Washer, M3 locking (qty 4)
M3-.05 Socket Head Cap Screw (qty 4)
Fits 1979-1985 Toyota Pickup/4Runner with solid front axle hub, and Toyota FJ80 Land Cruisers from 1990-1997.
Price on tacoma low profile front bumper, light bar, and ext cab sliders non welded shipped to 35117. Thanks
Trail Gear 2-Gallon Carrier
Tired of having fluids bouncing around in the back of your truck, buggy, and/or off-road vehicle? Our TG 2-Gallon Carrier is your solution to this problem. The TG 2-Gallon Carrier organizes and secures gallon jugs of your automotive fluids.
Our TG 2-Gallon Carriers are CNC laser cut and formed out of 16 gauge steel. The latch is a top-quality spring draw latch with a 200lb breaking force that features a safety catch to prevent accidental openings. Predrilled mounting holes are included so you have the option of bolting it on or welding it on to your rig. Shipped raw & ready to paint.
Fits most one-gallon coolant/anti-freeze, gear oil, and hydraulic fluid containers.
**Made in the USA**
