s10truggy Well-Known Member Joined Dec 16, 2011 Messages 97 Jan 22, 2012 #1 I got a question need an answer I got a th350 transmission that's blowing fuild little dipstick anyone got an answer why
J JRowe Well-Known Member Joined Mar 24, 2009 Messages 715 Jan 22, 2012 #2 contact KILLERB468 on here, he should have an answer
wizzo Well-Known Member Joined Dec 5, 2007 Messages 1,988 Location glasgow, ky Jan 22, 2012 #3 If its blowing out the dipstick is the vent on top plugged up?
monster monster buggy Joined Mar 9, 2011 Messages 496 Location arkansas Jan 22, 2012 #4 wizzo said: If its blowing out the dipstick is the vent on top plugged up? Click to expand... thats right check vent
s10truggy Well-Known Member Joined Dec 16, 2011 Messages 97 Jan 22, 2012 #5 Could you be anything else
K KILLERB468 Well-Known Member Joined Oct 10, 2010 Messages 249 Location Hendersonville Tn. Jan 22, 2012 #6 Blow air in the vent, spider/mud or what not may have clogged it. if clear it is possible that it is overfilled with the small dipstick.
K KILLERB468 Well-Known Member Joined Oct 10, 2010 Messages 249 Location Hendersonville Tn. Jan 22, 2012 #7 if it is too full and the trans is getting really hot it will spew as well, do you have a quality trans cooler on it? what stall and engine are your running as well as what gear and tire combo?
musselman Well-Known Member Joined Feb 18, 2009 Messages 160 Location Jacksonville AL Jan 22, 2012 #8 Might be a broken accumulator spring
K KILLERB468 Well-Known Member Joined Oct 10, 2010 Messages 249 Location Hendersonville Tn. Jan 22, 2012 #9 musselman said: Might be a broken accumulator spring Click to expand... that would just make it shift firmer, most quick shift kits have you leave that out or plug the feed hole.
Crawl Works Well-Known Member Joined Mar 22, 2011 Messages 242 Location Middle Tennessee Jan 23, 2012 #10 Buddy had one do the exact same thing the vent was plugged blew it out and worked great could be over filled to
s10truggy Well-Known Member Joined Dec 16, 2011 Messages 97 Jan 23, 2012 #11 It had a clogged vent tube
