P
If its free, its P
Just wanted to let you guys know , if you need a leveling kit or lift for your DD's or crawler hauler's give us a shout we are and Authorized Dealer of Truxxx products!!!
www.truxxx.com
We are based in Tucson Arizona, only 60 miles from the border of Mexico, in the Sonoran Desert. This company was formed because we felt that there was a shortfall in the marketplace - no company was focused on simply lifting and leveling the trucks and SUV's on the market, making the truck look the way its designer intended.
All of our kits are designed with 3-D modeling, using the latest in computer design software. In fact, we start with the manufacturers own drawings for our initial prototypes - but we don't stop there. After its design is complete in the virtual world, we test fit it to several different trucks in order to account for any production variances from the OEMs.
All of our products are made with the latest in computer controlled laser cutters, as well as a computer controlled punch and plasma cutter. All the kits are precision welded in jigs for accuracy and then powder coated. Even the box the lift kit comes is is upgraded, custom boxes and special inserts used instead of the cheaper bubble wrap or paper.
All the nuts and studs we use are top quality. Where the OEM uses a 10mm stud, we use a 10mm stud - there are no short cuts with our kit. The nuts we use are the more expensive serrated flange head nuts, with the built in washer. We could have gone with cheap hardware, but why? Our obsession with making the highest quality kit is evident in the details.
All of our kits allow the use of stock tires and wheels, so you won't get stranded when you get a flat tire and our kits maintain stock track width. It's the little details that make the difference - we decided to concentrate on one thing and to do it really well, and that is lift and level kits.
Unlike other kits on the market, not only can you install our kit easily - you can remove it easily too! Just in case you wanted to lift a truck you had leased, and didn't feel like losing your investment. Why give the car dealer too much of your hard earned money?
Hit us up with your needs at [email protected] or call us at 913.294.9320
[attachment deleted by admin]
www.truxxx.com
