Stomperbob1
Member
- Joined
- Mar 3, 2015
- Messages
- 5
- Reaction score
- 0
Custom rock buggy propane injected 5.7 350 th400 trans b&m shifter with atlas 3.8:1 2 speed transfer case, ball joint 60 front all stock not locked and 14 bolt rear welded, has disc brakes all around willwood dual master cylinders with separate front and rear pedals, corbeau buckets with 5 point harness. Hydro steering not sure on the brand with single ended ram, setting on fox 2.0 air shocks, will come with 5 propane tanks and a nitrogen tank for shock adjustments. 38.5 uncut boggers on the front and 39.5 cut boggers on rear on recentered h1 dual beadlocks with rock rings tires still have good tread on all but do have some plugs in a couple sidewalls, 10k winch needs a little tlc and some paint but is a great running buggy. Need to clear space in the garage as I now have a sxs so no longer need the buggy. Make offer or willing to trade for a few different items of comparable value. 12k obo located in Walton KY
