Sold/Expired Turbo 22r aw4 40€ stickie treps chassis
stuftmunky2k
Marysville, ohio
Buggy will be getting torn down starting November 6th.
Motor will be sold turn key. Built 22r turbo on propane from gotpropane. Motor has 12 trips on it. Bored .060 over, cam, head work, head studs, mls gasket, hypertectic pistons, new psc pump with 2 trips on it, new alternator with 1 trip on it, new dizzy, crane ignition box with rev limiter, will come with 4 propane tanks. $2500
Trans is aw4 with toyota bell housing it is currently bolted to the 22r. Running winters shifter that makes the trans a manual valve body. Will include shifter with transmission sell and everything to bolt to toyota motor will also include spare transmission. $900
5 stickie 40€ treps mounted on aluminum walker evens double beadlocks toyota pattern. 4€ or so back spacing. 4 tires mounted one has no wheel for spare. I will not separate tires from wheels. $3000 obo
Located in marysville ohio call or txt 937-243-twoninetwofive
willing to travel to help make a deal with a deposit. WILL NOT SHIP
Looking for hi pinion 9€ thirds, 39 reds on 8x6.5 beadlocks, rear steer axle.
Jcampbell54 said:
Will a toy gear driven transfer bolt to that trans?
Sent from the mans IPhone.
It will not the input is different diameter then output. A dana 300 will bolt right up tho. I have a atlas behind it.
Really would like to sell the shifter with the transmission to make it a complete package
Re: Turbo 22r aw4 40" stickie treps chassis
Is the chassis all tube,or is it a juggy?
What's the compression ratio on the 22r? Other than the 60 overbore are pistons from a certain factory application or custom?
Was this engine originally a turbo setup?
What manifold and what turbo?
Motor is roughly 8.5-9:1 on the compression
Pistons are sealed power hypertectic pistons. Pistons of all sizes are readily available for this motor
Motor was specificly built for the turbo. But was an original 22re
Turbo and manifold is from got propane.
Someone buy this so I can stop drool over it bump for ya
derail
what gear set do you have in the atlas and axles, and what did you like/ not like the setup?
3.8 in atlas 5.29 in axles on 40s. Loved the setup if i ran it again i would put a little bigger stall on convertor thats the onlything i would change. Its a stock convertor think its at roughly 1800 i would try a 2200-2400 but thats just me.
Re: Turbo 22r aw4 40' stickie treps chassis
Make a hell of a deal for someone that wants some weeepow
