5.3 aluminum block
Texas speed 220r cam and pushrods.
Pac racing valve springs
60lb injectors.
Stainless steel headers and up pipe.
Borg warner s366 twin scroll turbo.
Twin 44mm wastegates
Turbosmart BOV
Gm 3 bar map sensor.
Swap specialties standalone harness.
Speed density tune.
Aem meth injection (to cool intake air temps)
Summit racing fuel pump 385lph.
Jaz fuel cell.
Billet summit fuel filter
All fuel lines are black AN lines and fittings
Coolant lines are -20
Goatbuilt alt and ps pump brackets.
Psc tc pump
Summit racing radiator,twin electric 10" fans
K&n air filter.
3" exhaust with bullet muffler.
New alternator.
New starter.
New water pump with -20 billet thermostat housing
New tensioner
New serp belt
All new plugs and wires
Spent close to a full day of tuning on the dyno and tons of drivability
ReBuilt th350 trans with stronger sprags
B&m trans cooler
Full manual reverse valve body
Winters sidewinder shifter
Northwest fab atlas shifters
2500 stall converter.
Advance adapters flywheel kit
Advance adapters tcase adapter
Atlas 4.3:1 1350 non cv yokes
Wide open design drive shaft kits .25 wall tubing
Wide open design midshaft kit
Wide open design carrier bearing kit
Wide open design limit straps
Optima red top battery
Ballistic fab battery box and hold down
Dana 60 kingpin
Barnes high steer arms
Detroit locker
5.13
Chromo inner and outer shafts
Yukon superjoints
Psc double end ram kit
Artec truss
Rcv slugs
14 bolt
Spool
5.13 gears
Disc brake kit
Pinion gaurd
King 2.5 air shocks in front
King 2.0 shocks in rear
Twin wilwood pedals (separate pedals to control rear and front separate
Longacre steering wheel with quick disconnect
Wilwood master cylinders
Nickel copper brake lines
7/8 heims 1.75" dom 1/4 wall arms
Quickcar switch panel
USB power port
Rzr seats
40" maxxis treps
Tmi bead locks on soft eights
Chassis made by rockwood offroad
19k obo
60lb injectors.
Turbosmart BOV
Speed density tune.
Jaz fuel cell.
Psc tc pump
K&n air filter.
New alternator.
New starter.
New tensioner
New serp belt
B&m trans cooler
Dana 60 kingpin
Detroit locker
5.13
Yukon superjoints
Artec truss
Rcv slugs
14 bolt
Spool
5.13 gears
Disc brake kit
Pinion gaurd
USB power port
Rzr seats
40" maxxis treps
19k obo
