UPS brought me a present today
crazybluerider1
Portland
mmmmmm bender :redneck:
I whipped up a stand out of a hitch receiver and some 2x2 tube and welded it to the side of my trailer for mobility. Should be a pretty solid mount. I can always hook the trailer up to a truck or something if it moves around too much when I'm bending the tooob.:awesomework:
Sweeeet !!
That JD2 is top quality. Don't forget to butter up you tubing with WD-40 prior to bending: that tube looks a little dry...
I'm not actually bending that tube. I was just making sure everything fit right. My order of 1.75x.120 won't be in until monday, then I get to start bending up a cage. Thanks for the tip on the lube:awesomework:
To the people that are using JD2's. How long are your handles?
Mine came with I think a 4 foot handle. Most of my work has been with 3/4 to 1" steel and aluminum. I made a short handle about 24" and it has more that enough leverage for that small size tube.
i like the degree ring it had precise measurments
do they make a 3 series now?
air over hydro :awesomework:
go down to harbor frieght and pic up a cherry picker long travel air over hydro cylinder for under a hunskie and it will make life good :cheer: . You will have to bend vert. but that is a good thing :cool: ..
My handle is about 3" long and under a bench somewhere I think. If you plan on doing any amount of tube it's all about the hydraulics :awesomework:
**** if you had some arms on you . :haha: :haha: the handle work great.
