V6 Toyota rear gear strength ???'s
Avanteone
Auburn, WA
Currently in our '07 FJ Cruiser, we're running 5.29 gears with 35" Toyo's and a spool. We originally chose the 5.29's for the deepest ratio we could get without a sacrifice in strength. We need more power, or more gear... and obviously more gear is cheaper. Is there really a huge strength difference or loss with 5.71's? We see very little air time, and drive fairly conservatively. Our goal has been to finish races, not push as hard as we can. We're not making lots of power (stock 4.0), not running a doubler or any low range in the t-case at all. Any input?
John
the rig:
In most wheeler applications they dont hold up at all. Although I cant even keep 5.29s in one piece either.
That rig you race is heavy also.
I would vote for power adders if possible.
No 4x4 at all? So no front gears needed?
The V6 gears vs 4 cylinder aren't like a Dana 44 vs a 60 but they are roughly 20% stronger. The biggest strength comes from the V6 3rd member itself with its extra ribbing and thicker flange being so much more resistant to deflection of the pinion gear away from the ring gear.
There is a good tech article on pbb concerning running 5.71's and how to set them up for longevity. I'll keep searching for it...
i say get them and give it a shot.you are definatly rolling the dice. take them to bobby to get treated for sure just for good measure
Power adders are $$$, and rules prevent turbos, supercharger, etc.
Gears are sponsored, so I won't be out any money if we break for that part of it, I just don't wanna be 1000 miles from home in the middle of a race when I find out they're too weak. We've got some time, maybe some testing with the deeper ratio is in order.
Thanks for the links WT, I'll do some reading tomorrow.
Changing out the that toyota diff is out of the option too im guessing?
The general theory is the deeper a gear, the less strength.
If it was me i would run it. Test it, but run it.
cool rig!!
i have seen many more broken 5.71s then 5.29s on the trail(usualy like anything driver hammered down a lil.)..maybe if you got them treated like earlier said.
but if you are sponsered i guess free is good and having the abilty to change them,but i dont think anyone can give an honest answer on how they will last for your app. im guessing you guys are gonna have to do some weekend test runs :cheer:!!
Here's the scenario... if it was MY rig, I'd swap into a 9" and run a 6.40 gear or something. The rig is owned by Toyota North America, it's a long story, but they are taking the rig back at the end of the year and crushing it (obviously after we remove all the aftermarket stuff). It was a test mule for Toyota and there's some federal law about them having to crush it after a certain time period. We got informed a couple months ago that the time period was later on this year. So to answer your question, no I don't want to go to the expense of fabbing something custom at this point.
Can you lose any weight off the FJ? What about running a 33" tire. Both will make it seem to have more power with out changing gears.
Not really. When we got the rig, we pulled almost 700 pounds out of it. It still had rear hatch, steel hood, all power window stuff, etc. We ran 33's when we first got it and were getting buried in EVERYTHING. It's not BAD now at all, just always looking for more.
Interesting..... Well in that case I would just run the current gear set. Unless you can really get some rough tests in on the 5.71 to give you some confidence.....if not then just run what you got. I would take known reliability over a little power benefit.
I'm going to pull our 3rd out now that it's got approx. 1k of race miles on it, and inspect and see what it looks like. Gonna check my calendar, I'd love to get a hundred test miles or so on a 5.71 gear set and pull it to check it out before we get to an actual race. I guess I'll wait and see how time pans out... otherwise I agree with you, reliability is better.
any updates?
did you get to pull your 3rd? if so hows it look with that much abuse?
not sure if toyo is a sponsor, but i bet you could drop 20+ pounds per corner in rotating weight by switching tires.
Oh trust me, I've thought of that. The Toyo's wouldn't have been my first choice, but yes Toyo & Les Schwab are sponsors... so free tires > lighter tires. :haha:
I know third members are not light at all but why not just
Carry an extra just in case until you figure out if it's
Strong or weak.. Better safe than sorry 1000 miles out..
