natedawgxj
Crawldad
Longfield
Yukon super joints
nitro Excalibur
ctm
Yukon super joints
nitro Excalibur
ctm
natedawgxj said:Sorry I was wondering which one is the best one for the money
tonybolton said:I think if I ever switch over to a needleless U-joint I think I would get the one that has only one zerk fitting. I didn't like the way the Dana 44 Yukons I had were in the caps.
patooyee said:What say ya'l about running aftermarket joints in OEM shafts?
truckbroke said:Yukon super joints Nate.. 400 bucks a pair at ECGS.. The Spicers are tough but them *****es break. When they do you usually mess up the ears on your shafts cause there breaking under a load. Yukon will warranty your first break no questions asked but, will give you some **** after that. Reason being when they see broke ears they know technically their shaft didn`t fail your joint did. Which makes sense really. I wouldn`t want to be replacing my broke shafts because someone used a cheaper joint that failed.
