84Toyota4x4
Ok, so Im trying to set up shocks for the first time, and Im having trouble deciding which shocks to run on my truck. I have both 12" and 14" 5125 Bilsteins. Im trying to figure this out for the front. The rear is ok, Im pretty sure Im using the 12" shocks. I could actually probably get away with 10" shocks, but thats not what this is about right now.
Anyway, here are some measurements, as well as shock dimensions. Help me decide which ones to use please :eeek:
Front full extension - 30"
Front full compression - 18.5" (front springs are basically flat at about 19.5", slight negative at 18.5")
Rear full extension - 24"
Rear full compression - 19.5"
12" shock full extension - 29.7"
12" shock full compression - 17.91"
14" shock full extension - 34.9"
14" shock full compression - 20.75"
Im thinking I can pull off the 12" shocks in the front if I pull the stock shock mounts, move them in a little, and use taller ones, that will make the front full extension less than the 29.7" that the 12" shocks are. This obviously means the compression will be more, but bump stops will solve that.
However, if I use the 14" shocks, I have to limit my compression a bit down to 21" or so, versus the 19" or so I could do with the 12" shocks if I make the lower mounts higher. The advantage to this is I dont have to worry about droop, which means I dont have to move the stock lower mounts or mess with all that, just build bump stops and go.
The rears fall right into the rage of the 12" shocks, so I think I will be fine with that, right?
All opinions are welcome. It seems like using the 14" shocks up front will be "easiest" because of needing to do less fab work, but I dont really want "easier", I want "right".
~T.J.
~T.J.
