Sold/Expired Wimpykid 2.0 Buggy Sold
wimpykid
Beware the Skinny Pedal
As title reads, I am selling my rig. No sob stories to tell, just got something else going on. $15,000 or reasonable offer!!!
Here is the simplified version: YJ based buggy with 347 SBF stroker w/ FiTech Fuel Injection, C6 trans, STAK T-case, built HP60/14 bolt, 4-linked w/coilovers, and cut 44TSLs on 15x10 beadlocks.
Engine bay: 347 SBF with canfield 192 heads, Comp XE282HR cam, Harlan Sharp 1.6 roller rockers, Edelbrock RPM Air Gap intake, FiTech fuel injection (fuel pump and filter as well), custom built long tube headers, 3" mufflers, MSD distributor and 6AL ignition box
Transmission: Newly (installed 8/16/17) rebuilt C6 with upgraded servo and other parts, 3200 rpm billet stall, B&M shifter, TCI reverse manual valve body, Derail cooler w/fan, STAK 3 spd T-case w/ triple stick shifters, front and rear drive shafts have 1350 joints, and a spare rear shaft
Axles: 78-79 HP dana 60 w/4.88 gears, welded, 35 spline chromo inner and outer Yukon shafts w/super joints, Warn drive flanges, Reid outer knuckles w/ high steer arms, 3/8" diff cover
14 bolt rear shaved 1 1/2-2" w/ 4.88 gears, welded, stock shafts, 3/8" diff cover
Chassis: Started life as a 1989 YJ, but only has about 4' of stock frame left. 1 3/4" x .120 wall HREW tubing, 4 linked front and rear w/FOA coilovers, 2 1/4" x .375" wall DOM lower links w/1 1/4" heims, 1 /12" x .250" upper links w/3/4" heims
Tires: Cut 44" TSLs on 15x10 Eaton beadlocks w 1/4" outer rings
Other
: Mastercraft seats, Smittybilt XRC 9500 winch, KRC power steering pump, double ended ram, Autometer tach
I may have missed a few things, but that's most of it.
I built this rig with the help of friends and family, so I know what it is and what is isn't. I will sell it to whoever comes up with a deal I can't pass on, but anyone interested needs some experience on the trails. This thing gets you places in a hurry and will get you in trouble
Located in Jacksboro, TN (about 35 miles north of Knoxville) Name is Michael and can be reached at 865-seven ONe nine-4359
Also have a 16' w/2' dove gooseneck low trailer w/3/16" driveover fenders that can go with it for a fee, if the rig sells. Not pricing the trailer unless this sells
Re: Wimpykid 2.0 Buggy for Sale $15,000
I think he is still high from Ryan and Alex's propane fumes :wtflol:
With that said the Wimpykid can flat work.
I don't really want this to sell, but here's a bump with a video.
https://youtu.be/fKx0pkLqnpA
https://youtu.be/Jfay5YO5HVk
Bump for a badass rig. That means a lot if it's Ford powered and I'm sayin it! :****:
What radiator and shroud/fan set up is that. Glws. Ford power ftw
I'm thinking it's a Griffin radiator. I know dimensions are 22x19 with summit shroud, and Syclone 15" fan.
Radiator has been in this rig since 2009, so it does pretty good to be that small. Although I don't have much summer ride time, maybe 5 rides, with this engine setup, I normally can trail ride without any heating issues. It hasn't bothered me enough to change it yet.
1tonrenegade said:
Well ain't that something!? Good going rig! GLWS
I will continue to ride until it sells.
All PMs have been replied
Price drop. $14k. Noted in title
Shoot me some offers, I might like it.
Re: Wimpykid 2.0 Buggy for Sale $14,000
Why would you want to do that?
Oh yeah, to make sure you never broke any parts, other the motor! ;)
Is there a build thread by any chance. I'm building something similar 351,C6,208 with 14 bolts...
Sorry, no build thread.
I do have several pictures while I was doing the front section I could send you.
Thanks.
It's gonna be on the trail somewhere this weekend. Maybe GMP, maybe sandmines. Haven't made up my mind yet.
Price drop. $12,500 or reasonable offer.
Ready to ride!
