winch problems
bigred_086
auburn
My winch runs,the cable goes in and out,but has no power to pull a load.I had the battery tested and it's fine.Any ideas,Its a x8000i warn,:booo:
Same thing just happened to mine (xd900i), I took the winch in and had the motor tested and it was toast. New motor is on the way :cool:
Is your winch grounded directly to the battery, or is it grounded through the frame? Those flimsy factory grounding straps fail quickly when pulling the amps required to run a winch. I have a cable going directly from the battery ground to the winch casing. :redneck:
