hokie_yj said:This is the shifter I have. Unless I'm thinking about it wrong if you moved the cable to the front of this one you'd be pushing instead of pulling to shift.
http://www.racereadyproducts.com/automatic-shifters/winters-sidewinder-standard-shifter/
fabricator1 said:I have a winters sidewinder. New but mocked up on a turbo 400
patooyee said:It's been years since I did it but I believe you can just switch sides that the end of the cable comes at the shift arm from and it push / pulls the correct direction again. So if it's a rear cable the cable comes at the trans from behind. If it's a front cable the cable comes at the trans from the front. But either way I'm interested. PM me your price ...
How much? If Patooyee passes im interested. Thanksfabricator1 said:I have a winters sidewinder. New but mocked up on a turbo 400
Sent you a pm. I also have a Fairbanks gate shifter for a 400 trans with reverse pattern. Used in good shapepatooyee said:I agreed to his price via pm but have not heard back yet...
