got 86 4runner 22rec that i am trying fix the iacv. the connector i have has a brown wire with a blue wire and the truck harness has blue and a white black. how should i wire the connection?
Sorry I can't help ya... Sounds like you've got a 50/50 chance... Maybe a yota guy can chime in and tell you what will happen if you guess wrong... If reverse polarity won't kill anything... Then it'll either work, or won't... Perhaps it'd be a good idea to hook up a multimeter to it and find out which side of your current plug has power... Then hook up the white wire with the black stripe to the opposite wire... Black stripe on a wire screams ground to me .... But... That's just my semi-educated guess... Good luck!
