BIG_Country
I'm looking for a Dana 20 transfer case
Hillbilly said:Think I've got a J shift early bronco one behind the shop. If that's what you're hunting.
patman said:I've got a Dana 20 in Augusta Ga.
It's attached to a t-15 and an AMC bellhouse, with a new-ish clutch. No shifter since it was set up as twin stick and i kept all the linkages.
Dana 20 has new seals, and was used up until a recent trans/tc swap. Has CV yokes as well as stock yokes
BIG_Country said:Well it bolt up to a dodge np435
patman said:Probably not... it's from a jeep and has the Texas bolt pattern. Not sure what dodge used
fordcontraption01 said:I've got a dodge auto trans and 203 case if you need that route
TBItoy said:Hey I talked to my buddy at work, he has a Dodge 360-NP435-205 combo (435/205 is a married 23 spline setup),( apparently 29 spline 205 was from the dodge diesels with the getrag trans).
The 205 is in his garage, but the engine and trans has been sitting outside for several years so condition is unknown/not guaranteed to be good. It ran and drove fine when pulled from the truck.
$500 for all of it.
a dana 20 t/case will not bolt to a np435 without an adaptor.......if you want to get creative, I have a divorced mount dana 300....yes divorced 300..its a freak..612-309-3999.................612-309-3999BIG_Country said:I sent you a pm
geardaddy said:a dana 20 t/case will not bolt to a np435 without an adaptor.......if you want to get creative, I have a divorced mount dana 300....yes divorced 300..its a freak..612-309-3999.................612-309-3999
