SPOA87YJ
coo-whip
- Joined
- Aug 3, 2008
- Messages
- 127
Package deal --> $850! Located in Charlotte, NC.
74/75 W250 Dodge Dana 60--8x6.5--Drum brakes
WMS is 65"
4.10 gears
Welded
Set up for spring over
Ruff stuff 3/8" traction bar mount
Ruff stuff anti-wrap spring perches
Blue Torch Fab spring plates
U bolts
1330 yoke
Diff Cover
Brakes lines included
NO e-brake cables
I put new seals in it a few years ago and believe I have a set of spare shafts laying around I will have to look.
This axle will bolt into a stock or stretched yj and I think xj's as well. However, the only things that will have to be changed are the pinion angle and shock mounts to make sure they fit your wheelbase/shock orientation.
It looks like an axle but here is the best picture I could find
Springs pack consists of stock XJ packs with an s10 main leaf added in. I installed brand new grade 8 center pins 2 weeks ago and they have only been on one trail ride since being rebuilt.
Springs have brand new custom made spring clamps using 5/16" hardware and 1/4 plate.
Also have some custom made 3/8" shackles and hardware.
Best picture I have..
Built this traction bar last year. Uses bushings on all 3 ends with a shackle at the frame. Newer grade 8 hardware included.
WMS is 65"
4.10 gears
Welded
U bolts
1330 yoke
Diff Cover
NO e-brake cables
