RTW work party sunday 22nd
Sorry I couldn't make it in time to help out. I was not able to get a trailer until 2pm on Sunday, so by the time I got loaded up and back out to Reiter, it was too late. being at the mercy of Uhaul sucks. nonetheless, I saw some of your work and I hope (for the sake of all who did the work) that nobody messes with it
Thanks for all the effort
Terry
Terry
We saw you rolling in pretty late sunday
I had a Tamer event I committed to prior to knowing of this, and this girlie can't ride two horses with one ass. I'll be sure to look out for the next work party.
great job guys/gals
I was only able to get to the entrance of cable trail tonight. But the entrance is barricaded. All the logs are lumped together with cable. Good work on this guys,
This is the creek crossing on back door. You could see where folks were going off the trail and above the creek to where the muck is (mainly bikes). Due to the type of creek it is and having natural filtering to it I decided it just needed some barriers to keep people off the edges of it.
We also made platforms for the logs to sit on, so they were not on the ground and possably causing the water to back up against them.
Heading tor wards the rock garden, not too far past the creek crossing there was a new bypass. Both sides of the bypass have logs that we lifted via winch's and stuck between stubs/trees and off the ground.
Just beyond that there was another new bypass to the left. We used one large tree stuck up on a stump and again off the ground in the middle of the bypass.
This root ball you used to see only the bottom of. We cut the log and double winched the tree/root ball as a blockade
Some of the smaller blockades
