Yum... Tacos
You know, sometimes I think I do some ghetto work and patch mine together not the correct way. Then I see a Crash build and I KNOW I'm doing a ghetto job lol
Unboxed everything and organized it.
I am no big fan of trail gear stuff but this isn't mine and it really does make the job easy--especially for the taco's.
He got everything, housing, six shooters the whole works.
Will also be doing a rear disk conversion also.
What's wrong with the trail gear parts?
Passenger side burned in.
Getting driver side positioned and looks like going to have to cut deep into the body. Have had to do the same on the mini trucks.
Frame is drilled for the steering box and frame plate ready for some heat.
Inner brace for the steering box all burned in.
Now to give the steering box some room. Chop chop goes the sheet metal
It was chop and install the box then rinse and repeat until i got the fitment i wanted.
After I got the fitment I made an insert. I welded the seams that were separating and then made an insert and welded it into place to regain rigidity in the core support.
