angryfab one seater aka (problem child)
Re: angryfab one seater
:rolf:
Hangovers suck. I usually just moan and writhe in pain in bed until late afternoon :-X
angryfab said:
Got up this morning with a hangover . An thought what can I do that is easy so I tacked up the other header for thr one seater . I will tig it up an grind it when I feel better
cant wait to see u in the woods with this thing but for all the fab ur havin to do on it "problem child" is the perfect name but I no if anybody can get it together ur the man...keep at it George its lookin good
I got to sit in this unit sat..its very comfortsble..an one awsome lookin unit.cant wait to see george gassss on it
Damn found my build thread on page 4 . Well here is what I did on the shifters . An got a whole bunch of little bitty **** done that nobody cares about
Rokcrler said:
Looks like you push the shifters out and in? How easy are they to shift?
if you mean how easy it is to move them its really easy . This way siting in the seat all I got to do is move my hand down an shift . An nothing is in the way in front of me
Ok got the fuel cell done it came out to 13 gallons before I put the bottom sump on
Also built the battery box an mounted some switches an push start on the shifter
Ok so one seater that means drive shaft wright under seat comes apart me got problems.
So I built a new drive shaft out of 3/16 tube an put the slip at the axle end an built a drive shaft hoop an then plated from my seat crossmember to the hoop with some 1/4 in Ar 500 impact plate .that should take care of it
If anybody has a better way let me know
I would make sure you cover all your seating area I had a teacher in high school that was a NHRA driver before going into teaching that had a drive line come apart under him and let's just say you don't want that happening to you he just about died from it and still walks with a limp and has problems from it!
I would say cover joints and all just in case.
Oh by the way this thing looks awesome!
Tks bud! I will that's kinda what I was thincking I will post up what I come up with . I do need the rest to be able to un bolt because of being able to get the t case out with out to much anger
Ok I got something in mind .shouldn't be a problem maby I can get it done today an I will post some pictures .
It is mount radiator day for the other 3 buggys in the shop .YA!
Ok I thinck this will work the cross member that the front side is welded to comes out .also got started on a floor an got some water plumbing done
I also got a radiator mounted an the motor guard built on a chassis I built last week
Looks great man! You can just swap all my parts over to that for the price we talked about! :rolf: :rolf: :rolf:
