zayne2427
There's only one way to find out
I built a 4'x10' cement storm pit in the ground under my stairs. The door/lid to open it will weigh around 135-145 lbs . I need some ideas on some struts of some sort to help with lifting the door
mna0121 said:Use a counter weighted pulley system anchored to the underside stair treads. Block and tackle to make it easy open
JohnG said:You could trap a child or female in your shelter.
fordcontraption01 said:Get a couple shitty air shocks with bent shafts or gouges in the chrome part and use those
Cracksrubi said:At my old house I had a fiberglass door so I kept a hatchet in there in case we got trapped. If your door is metal how will you get out if you get stuck. Only reason I ask is be cause we didn't have cell service in ours while we were down there
