jmh78
What are some opinions of 14 bolt shave kits?
Been looking at the TMR 15 bolt kit but a little unsure about the strength reduction if any after the ring gear is turned down. Also wondering if people have problems with diff cover leaks after shaves. Do you gain enough without cutting the housing and just running a Crane High clearance 13 bot cover?
Has anyone with big tires and big power ran a shave kit that requires ring gear machining?
But it seems like it would last much longer with repeated beatings
