1988 Toyota 4Runner 4x4. Automatic Transmission V6.
Removable Top!
Removable doors! Door connects have been notched so taking doors off and on with one person is very easy.
Head Gasket has been replaced as well as timing belt.
Heat and AC work.
It has 3" All Pro lift springs up front,
High steer setup,
factory calipers,
1982 FJ40 rotors (this is the combination you have to do to have vented rotors),
1985 front straight axle,
1.5" wheel spacers,
shortened rear driveshaft in the front (this was to eliminate CV joint in the front driveshaft),
4" long travel rear springs (cut factory perches off and welded new ones on that were 9" farther apart. Giving it more flex).
5.29 Gears and lockrite lockers front and rear.
Rancho RS9000XL 9-way adjustable shocks all around that have right at 12" of travel. Two Bilstien 5125 12" travel shocks come with it as well.
38x12.50x15 TSL Tires with approx 60- 70% tread left.
Will fit 40 to probably 42" tires as it sits now.
All brake lines have been extended to accommodate lift and flex.
Diff Armour front an rear
Tube Rock Sliders welded to frame.
Tube rear bumper was built by Jimmy Smith Motorsports and is welded to frame.
Custom front winch bumper/brush guard.
Spare tire carrier comes with but would have to be welded to rear bumper.
60" High-lift jack mounted inside vehicle.
Smittybuilt 2.5 Gallon AirTank with accessories.
Extended differential breathers.
Rock lights on all 4corners with switch beside steering wheel.
Tube doors.
Rust on bottom of doors.
Has a few dents and scratches
Just turned 238k.
Small oil leak. I haven't had it checked because of time and it is small.
I drive this truck daily and have never had a problem with it. Very reliable and will go anywhere and get you home.
Asking 7500obo.
Please Text me at 803-767-9007
ALL OFFERS CONSIDERED!!! but really need some cash because I just had back surgery and workers comp check I get is not close to what I was making.
All calls will be sent to voicemail unless you text first.
Pics coming
Removable Top!
Heat and AC work.
High steer setup,
factory calipers,
1.5" wheel spacers,
Tube doors.
Just turned 238k.
Asking 7500obo.
Pics coming
