Sold/Expired 1992 Ranger on Tons and Airshocks
NC
Email: [email protected]
Description: 1992 Ford ranger, Xcab, tagged, titled, lights, turn sig. horn, delay wipers(chicks dig delay wipers) stock flip and fold factory seats-easy access to stuff in the rear,Factory burgandy paint-there is a dent in the d. door not shown in pics-window and handle still work well. Ditto on p. side(not as obvious) Rear 15 gal. fuel cell and tool box in mesh "bed", cargo area is a better description
Now the good stuff:
WB is 112"
***** '79 F350 Dana 60 front with 35spline chromo inner and outer on driver side,35spline chromo stub and 35spline traditional on pas. side.New(one trail ride) LONGFIELD joints both, LONGFIELD drive flanges, 4.88 r&p, detroit, Ruff stuff diff cover,Factory front disc with new rotors and cal/pads etc....
*****'79 E350 Dana 70B rear, factory 35spline, 4.88, Detroit, C20Cheby, front disc brake conversion on rear, new parts when built , metal flex lines front and rear, 1.25" bore Master cylinder, stops WELL-an and off road
*****'95 5.0, 'stang motor, sefi, factory wiring grafted in with Ranger, diag. port still functional, air intake, and 2into1 exhaust, stock, 71k miles when installed. Red top optima behind pas. seat in box.......
*****Ron Davis double pass al. rad with their fan and al. shroud. 195 Tstat-runs 200 at 32degrees and snow or 90and sunny
*****Early bronco C4(well built),LoKar 18" shifter, Atlas 4.3 Tcase,
***** 3link front with trac. bar, chromo 3/4 heims on steering, top link. 1.25 heims on lower link
2.5 14" Fox air shocks on front
********Traditional 4link rear, same hemis as front upper and lower 2.0, 14" Fox air on rear. Sway bar on rear.
*****Complete PSC matched full hydro (pump, ram and res.) Steering,
*****1/4" skidplate under the Atlas
*****Exo cage is all 120 DOM
*****20lb PowerTank-the "big un"
*****60" Highlift
******This rig was built in the garage from Dec. '07-March '08. 6Trail rides in '08, This year, Moab in April, Gore, Va in June, Windrock in July......
*****17x9 MRW beadlocks with 39BFG Krawlers(over half tread
as described above PRICE is $15500
With NO Power tank and 15x42x17 TSLs (80%) tread instead of the BFGs also on 17x9 MRW beadlocks
Price is $14700
Thanks for looking
[attachment deleted by admin]
More pics. I am not the seller of this sweet Ranger his contact is listed above in the original post, please contact him with any questions, I can answer general questions all though.
