2000 4Runner Rear Axle Bearings (ABS)
mudmaster
Fife
Has anyone done this? How much of a PITA are the spacers and tone ring to get on and off? Should I just bring the axles somewhere to have them removed and installed? Thanks
Unlkess you have a junk axle housing to cut/make into a tool then good luck.
Even if you have a press, how ya gonna get a bearing splitter bigger than a backing plate?
Its a shitty job without the right tools.
Just find a national or napa that can press on the new one for ya.
It'll be going to NAPA once I get em out. Just wanted to confirm what I was thinking.
DO NOT REUSE, OR USE AFTERMARKET RETAINERS OR SIGNAL RINGS.
I have all the **** to do axle bearings, have done hundreds.
And even slight galling of the axle will prevent it from sealing properly.
Retainer and signal ring depth also have to be correct.
Will you R&R mine for me? If so how much $$?
Both sides, I'll be taking the axles out next Thursday (9/20) and should have em ready to R&R the spacers, tone ring and bearings on Friday.
Ok. As long as I either have the truck or untouched axles (not dissassembled or messed with) its no biggie.
Ok, I have most of the parts already. I just need 2 more spacers and the tone rings.
