benfowler87
Race Ready 2011 Polaris RZR XP 900 Built by Wide Open Design. I bought it a few months ago and have rode it maybe 10 times. Its a great built unit that will ride better than any out there with the King Shocks. KOH 2012 was the last time it was raced. 125 Hours. 1180 Miles.
2011 XP900 White Lightening
WOD 4130 TIG welded cage
WOD 4130 TIG welded bumpers
1/8" aluminum roof panel
WOD spare tire carrier
WOD fixed race doors (Don't rattle like Pro Armours!)
WOD A arms
WOD HD trailing arms with new heims
WOD number plates
WOD 7075 radius rods with new heims
WOD tail light panel
UHMW skid plate
BTF tie rod kit
Wrath Racing rear sway bar
EPI clutch kit for 28" tire
Lowrance HDS-5 GPS
Grant steering wheel
Twisted Stitch seats
Twisted Stitch window nets
Crow 5pt. Padded Harnesses
KING 2.0 coilovers with compression adjusters
Pure Polaris power steering
3 Lazerstar 12" LED light bars Two flood bars in roof line with a spot on the bumper.
Warn 4500 winch with wireless remote
Muzzy full dual stainless exhaust system
New Super ATV Rhino shafts all the way around.
New upgraded battery
Donaldson high capacity air cleaner relocated to bed
2 Fire Extinguishers. One mounted on passengers door and the other on the spare tire carrier.
Lug nut socket welded in the T-Handle
Wide rear view mirror.
Upgrades since I have owned it.
All 4 ball joints replaced up front with AllBalls ones.
Upper A-Arm bolts replaced with Holo-Krome Socket Heads.
Upper A-Arm tabs were welded with washer inserts to take up all slack.
Brake pads replaced all the way around.
All brake lines replaced.
Lug Studs and nuts replaced on font both sides.
Coolant flushed and filled again. No overheating issues at all.
Amp and two 4 1/2" Kicker speakers with iPod hook up.
Brand new Polaris crate engine installed by Basch Bros powersports in Cullman. I have the paper work where the engine has a 6 month warranty. engine and labor was over $5,000.
New starter clutch bearing also done by Basch after the motor install. This was over $300.
New EPI Extreme belt with less than 100 miles on it. Also comes with a brand new Polaris OEM belt.
New heims on the radius rods and on the trailing arms.
5 brand new GBC Kanati Mongrel tires. 28-10-15 all the way around. RBD at MM is the only ride on these.
There are 8 of the 15 inch OMF bead locks total with five of them having the new Mongrels. Also have the factory wheels and tires. All parts, filters, manuals, and everything else that I have goes with it.
$18,500 OBO Located in Cordova AL. 35550 30 minutes west of Birmingham on I22. Willing to meet or deliver depending on circumstances. Call or text 205-300-4902.
All pictures were taken today. Its clean, full of fuel and ready to ride.
WOD A arms
WOD number plates
UHMW skid plate
BTF tie rod kit
Lowrance HDS-5 GPS
