Sold/Expired 2015 ATC all aluminum enclosed trailer ready to haul your 4x4 priced to sell.
knaffie
everywhere
• 2015 ATC Quest enclosed trailer. All aluminum everything, all tube construction, best build quality on the market.
• 8.5' x 28' with 7' ceiling (6" extra height from standard).
• Tandem 7K Dexter torsion axles with brakes on both.
• 235/85/R16 load range G tires – you won't overload these!
• Extruded aluminum floor and ramp with full length double e-track + 4 heavy duty tie-down loops.
• 60" long storage well in floor is perfect for heavy items like driveshafts, axle shafts, gears, floor jack, etc.
• Cabinets will hold all your tools and supplies + a wardrobe cabinet to hang things up.
• Lots of super-bright LED lights inside.
• Power 3500# tongue jack (Barker Manufacturing USA-made high quality unit new in fall 2017).
• Toolbox on front is great for storing stinky spare fluids and anything else you want and also contains a deep-cycle battery and shutoff switch (runs the lights for days without recharging).
• Custom 3/16" steel ramps over wheelwells so you can drive / haul your 4x4 on them. They are removable if you don't want them. The factory wheel boxes are still there.
• 48" wide RV style side door with inside/outside lock.
• All LED exterior lights with two sets of tail lights.
• Identical spare tire mounted conveniently inside where it's easily accessible when loaded.
• Has mounts and bars for Blue Ox weight-distributing hitch, but the hitch itself was stolen, so it comes without it (can be purchased separately).
• Will hold a fullsize buggy / Jeep on 40" tires and full width axles + two ATVs with room to spare.
• Absolutely no oil/gas/chemical smell inside. We sleep inside it often and have religiously scrubbed the floor and wiped the walls whenever it was dirty.
• I don't believe it has ever touched the road salt. There is no rust on the trailer.
• It's in great shape overall with no major problems (I'm OCD about keeping my stuff nice), but it's not perfect. A few minor dents inside and out. Two ceiling panels near the back are in rough shape where my Jeep's cage rubbed it going down the road when a strap came off. These panels can easily be replaced (held on with double-sided tape). One cabinet door has a dent in it that could also easily be replaced, but the door still closes and latches fine.
• I have full prints from ATC I can email or post – just ask.
• Trailer is currently in Fort Myers, Florida. Will be in Southern Michigan early June. I can help with delivery.
• These pictures were taken at Christmas and the trailer has not moved since then. I have many other pictures and can take more – just ask if you want to see anything else.
• I'm $28,000 into this with all the extras. Priced to sell quickly at $15,000. Title is in hand.
The dimensions that everybody always asks for:
rear door opening: 90" wide x 85" high
58.75" between wheel box covers
11.5" floor to top of wheel box covers
262" rear door to back of road side cabinet
310" rear door to front cabinets
84" floor to ceiling
That's a good looking trailer. I've never seen storage in floor. That's cool
Any services done on the brakes, bearings, axles? Are either of the roof vents braced or wired for A/C? When are you headed North? Ideally, I would have a trailer as soon as possible. I am in North AL and Central GA depending on the day.
