22re wiring
Bluetoy is the man when it comes to Toyota wiring, you could P.M. him but its likely that he is covered up with work already.
Good, the 3rd gen wiring is better for doing a stand alone. What is it going in?
I normally build them stand alone where it will run with 3 connections at the ignition switch, ground, and a plug at the instrument cluster for the gauges if needed.
