I put a 98 4.3 Vortec in my 95 v6 4Runner. Im using the stock GMC harness. Downey says that i can use my stock fuel pump, I have everything wired up. I can crank it over, and all my ignition is hooked up bla bla bla. As of right now i cant get it to start up. After doing some reading and asking howell for some documentation for using my stock harness, there manual states that i must have a fuel pressure of 60 to 65 PSI. I be live toyotas efi pumps run at 45. Am i wasting my time using the toyota pump? Also if i don't have my Check engine light on the toyota hooked up to the MIL on the gmc ECM, would that not let the motor start, I wouldn't think so, but i figured i would ask. I have lots more trouble shooting, but it gets loud in a condo garage at night with open pipes and i cant keep cranking it over right know to late. Guess i will wait tell the daytime to continue with the testing.
THANKS
THANKS
