redline
I need to know if I can Run My gear ratio this far off? i got dana 44 with disk thinking of putting it in My 4runner 4;38f to 4;30r
I'm just wondering, why is it that you are swapping a d44 for a Toyota rear?
I got a d44 out of a rodeo with disk and is 60" wms to wms, and was thinking of a waggy 44 up front same wms to wms. i want to do something as i don`t like the leakey front end and the cost for toyota stuff is rediculas My toyota is built on a budget and i want to be able to continue wheelingon my lil to no budget. any input?
It's usually a function of having a different axle front and rear. 60 rear and 44 front would be 4.09 in the 44 with 45 teeth on the ring gear and 11 on the pinion gear. The 60 would be 4.10 with 41 teeth and 10 teeth.
Numerically they're not exactly the same but in reality they match...
It also has to do with actual gear design and tooth count that can vary even on the same axle.
I don't buy that. If the tooth count is the same then the gear ratio is the same. I would like to hear what one of those engineers has to say about it though.:beer:
you think toy stuff is pricey? just go fine parts for that rodeo 44 special gears lockers had one and got rid of it
didn't cornbinder run 4.10 in the front and 4.11 in the rear
